SJRC F11 4K Pro Toilet bowling
Rake1
Just wondering if anyone has solved the issue with the F11 toilet bowling. Mine does it quit regular to the point it is getting hard to fly. Seems to start out ok but then starts the big circle. I follow all directions for compass calibration and did a factory rest but still does it most of the time. Any ideas??
I don't have a F11. I do have a lesser version SJRC Z5, but that's irrelevant.
What I wanted to say is..... just in case: check your propellers. Make sure they are not installed either too tight or too loose. Make sure there is no damage to them.
Adding : Any chance the F11 has had a crash before you have this toilet bowl situation?
I have done the propellers before and they are good and not to tight. I have had a couple minor crashes before but the thing that get me about this is it doesn't always toilet bowel but it does do it more often then before. Enough that I don't trust it to fly to far out.
I have a Bugs 7w that is inclined to do the same (great description BTW, off this problem). I find that I have to take extra care with the initial stabilisation and compass calibration. If you rush it in any way or if there are steel objects nearby that don't bother other drones, it will 'toilet bowl' as you put it. I get around this, if it happens, by switching off the RTB when it is getting close by and then by bringing it back to land, manually.
well it is good to know other brands have this issue also. I too can use the cancel RTH to help but not eliminate the issue. I assume it is a GPS issue and I started using the UAV app but it doesn't at this point (2 Weeks use) help me. Always show not to fly so I am still lost with what to do. I do try setting it up as carefully as I can. Any other thoughts?
