Hi, I recently got an SG906 Pro 2 as my first drone as it came highly recommended. I then stupidly crashed it in a field on a breezy day not knowing about high speed mode. It had quite a bit of damage, the gimbal was hanging loose by the wires and one of the hinges were a bit slack causing the drone to lose balance when it moves. I managed to super glue the gimbal in place and it seems alright so far. But it has a scratch right across the glass cover of the lens and unfortunately it affects photos significantly. Do you think I could get a replacement sheet of glass or even just remove the glass for good? If so, how could I do it?
Thank you.
Thank you.
