Setting up ZAZA V2 systwm in a drone to run on 4 separate batteries... 1 per motor/ecu and 5th battery to power the Naza M V@ flight control system
Alpha One
SKYFOX Areo
I am working on building my own larger sized standard X Quadcopter. Using the NAZA M V2, I am trying to find someone that can tell me how to hook up the following set up.
Can I plug each motor & 30amp Bec/ESC with its own 11.1v lipo pack into the appropriate slot in the NAZA box and a 7.6v lipo plugged into the NAZA esp box? Is this too much power and it will short everything out or can the NAZA system handle this and distribute the correct voltage to the flight control system and the receiver?
The info and videos I have found show a single larger battery hooked to all the esc's and the NAZA system. For the one I am building I need all the battery's hooked up separate. Any help will be greatly appreciated. If this is not possible... is there a system commercially available that can do this?
Thank you
