Repair blades
Harry4563
Hello I have just brought new blades for my mtech sky drone pro and I have just broke 1 of my blades. the new blades are next to me now and I am wondering if I should do it myself or leave it and take it to a repair shop? If I should do it myself can I have the method to do it?
Don't you have the user manual?
Refer to it. It is not hard to do.
Just remember your drone has 2 different sets of propellers. One set should be marked A and the other B. Look closely, they should be marked.
Take a look at your broken prop. Find out if it is A or B, and you replace it with a prop of corresponding letter.
That's all.
Just to elaborate further......
Your drone consists of 2 sets of propellers, a set marked A and a set marked B.
Are are your drone's arms. 2 arms are marked A and the other 2 marked B.
A props go to A arm.
B props go to B arm.
That is a must, cannot be mix and match.
I have 4 arms and 1 broke how do I fix it?
What did you break?
A propeller or a drone's arm?
For a broken propeller, refer back to your user manual and my previous posts.
For a broken arm, say bye to the drone. If it is just the plastic arm that is broken and not the wiring or the mechanism, you might be able to glue it and duct tap it ( I did it once on one of my Eachine drones). Otherwise, it's history.
Adding : Slightly off-topic.......
Baking soda and crazy glue will bind broken plastic parts securely. I had an Eachine EX2H drone with a broken arm. I "fused" the broken plastic parts together plus duct tape for good measures, and it flew like nothing had happened.
