SavantWolf
Im very new into the quadcopter hobby but theres always been a question that lingered my mind when I built my first two drones: does a receiver with two antennas have a better range than a reciever with one?
I'm looking at the FlySky i6 transmitter and receiver combination. The receiver has two antennae. What is the best (and safest) method to mount them within a quad frame, to avoid damage to them, while not degrading their effectiveness?Usually, the receivers with a single wire are for micro or mini quads and are very small and light. Honestly, it will still have more range than your 5.8 video transmitter, so a better question is, does it matter? Not for most people.
Absolutely no point in spending 40 to 50 bucks on a fancy x9r long range receiver to go fly in the park when a 15 dollar micro will do the same job and take up 1/3rd the space on your build.
That is if you are talking 2.4ghz and not uhf receivers which often come with one wire too.
It's a good choice. Upgrade on range. What fcb have you got.I'm looking at the FlySky i6 transmitter and receiver combination. The receiver has two antennae. What is the best (and safest) method to mount them within a quad frame, to avoid damage to them, while not degrading their effectiveness?
 as far as "cannot mount them along the frame on a carbon fiber frame..." All of mine have been. Just run a strip of electrical tape underneath the wire and another on top to hold it in place.
carefully cut the outer insulation away exposing the coaxial shield, carefully remove the shielded braided wire to expose inner RX wire.
 The amount of exposed inner wire in a coaxial cable when used for an antenna is predetermined by the manufacturer.
Yup, but I have prop nipped antenna wires during a crash and cut them to even lengths then exposed the inner RX wire to manufactures recommendation (IE: FrySky XSR 4 = 32mm) and have had no ill effects, fly's just fine. Beats replacing the RX or waiting 3 weeks to get from China!
 ... Well now, THAT's completely a horse of a different color then ... lol ... well done !
