rc logger
Flyt time
hey guys, I hope sombody can help. I have a rc logger navigator. I have had this for awhile its been alot of fun. For some reason on the tx it says err1.0 . Because of it ,it wont let me calibrate it.Ive tried the place i baught it from no answer,I emailed the co. that they buy it from nothing.I cant find anything on trouble shooting online.If anybody can help Id appreciate it. thanx.
No idea really but transmitters do tend to drain batteries somewhat fast in my experience so would try battery swap before anything else. Beyond that would see if jumper T16 or radiomaster T18 with 4 in 1 module could bind to the quad and get one of those as a replacement (have bound to random things found in the forest using this tx and enough guessing, it controls all my quads with mix of DSMX and frsky and some flysky receivers as well now). Only issue there is need to do a lot of guess and check to figure out what channels are mapped to what on the quad originally and what values it expects if has arming or other mode switching coming from channels of data sent to the receiver.
Take some images of issues you're seeing and maybe someone else here has seen the same or similar but hard to guess or google with misspellings etc. (I know this forum can be unforgiving on edits and autocorrect can go bad but need to know exactly what the error is and parts involved to dig further I think)
Yah gotta use a photo resizer app or just share links to google photos or apple equivalent the people who host this site don't make enough to cover hosting I don't think off the ads so can't support a ton of media being on the site (believe me annoys me a bit too but also I understand to some degree especially with video, share that via youtube private upload and links if need be)
Can some one help me with RCLogger Xtreme transmitter problem? It turns on the motors but doesn't respond to throttle speed increase. Is this a transmitter problem or a flight board issue. Customer service for this product no longer exists.
Could be on either side, is part of the reason I'm such a fan of betaflight or other open source boards and components can better diagnose what's happening with betaflight configurator and adjust config as needed for random setups. On transmitter side needs to be sending the values for low to high that the receiver and flight controller ultimately expects on the correct "channel" on receiving side the limits for the low throttle and high throttle need to also be configured correctly or else when arming the quad may "think" the throttle is above 0 and ignore it, if throttle stick at 0 when arming though and still having issue then need to be able to connect to quad flight control board and/or adjust transmitter settings to work properly. One thing can know is since can arm and disarm the transmitter is bound to the controller but probably not a lot more info can get out of proprietary FC (assuming they didn't use a betaflight flight controller)
One thing to try also would be have quad off, transmitter on and throttle at 100% (props off) then plug in quad wait a few seconds and throttle down to 0 on the transmitter, this might work for recalibrating the 0/100 range is procedure usually used for calibration of esc signals from FC.
Anyone need adapters for their RCLogger Xtreme? Will sell 4 for $10 + postage. #2 3/8" long attachment screws and mini Pro 3 propellers can be purchased elsewhere.
I mounted camera. It won't fly again. DjI mini 3 pro is slightly heavier than RCLogger Xtreme so I thought mini Pro 3 props would provide good lift thrust.
Oof bummer, yah figuring out what people size/pitch is right for a given thing seems to be bit of dark art or messy science :) ecalc.ch always my go to for seeing in theory how a build or change should affect things but increasing the angle of incidence/attack on the prop could help ( could adjust your prop holder model to give them more tilt)
