props
joseph
do you have to use the same type of brand name props on all four motors. also do you have to set the trim on the kk2.1.5 board every time you fly. thanks
Hi mate its best to used matched props as some can be a lot heavier than others, so all the same make will keep props in a weight range ( they must be balanced before use) if your asking about the trim buttons on the transmitter , then if the transmitter is digital programable then it should remember trim setting , but normally if the KK is set up right with the right firmware it will not need to be trimmed
