DuaneM
Drone? I don't see any drone ... crap!
I have 6 Scorpion GAUI motors that have a 17mm x 3mm shiny chromed? shaft and every prop adapter I have just spins off after a few minutes in flight. I tighten these damned things until I break the allen head wrenches I have to use to tighten them (actually broke 3 of them).
I have two types I have used on these motor shafts, one type has the little 2mm allen head stud on opposite sides of each other and a compression type that squeezes the shaft as I tighten the prop.
In my internet searches, I have only found these two types and they always spin off.
Do you know a "fix" or where I could find something better?
I've never replaced a motor shaft, I don't even think it's possible with these motors since I can't even find replacement shafts anywhere. I have been considering filling in the empty space between the shaft and adapter with superglue, but I have no idea if that would just make things worse.
I really hate the idea of throwing these motors away, I really have a hard time throwing anything away!
