PLEASE HELPP!!!
Don12345
I connected the Qbrain ESC, HobbyKing V3 multi-rotor control board and hobbyking 6ch receiver. This is the first time I have done this. I calibrated the ESC and tested if the motors were working just with the esc connected to throttle on the receiver and it seemed to work fine. But when I connect it to the control board I get a light on the receiver and a continuous beep noise, and when i turn up the throttle none of the motors turn. Please suggest what I should do to fix it. Please reply asap .THAnks!
What is beeping? The receiver or the ESC(s)? Obviously you don't have a binding issue between the tx and rx and you're able to get your motors spinning without the board in place. There's not really enough info to pinpoint anything more specific from my end, but I'm assuming you missed something in the configuration of your board, or you've connected from your receiver to your board with the channels in the wrong order - or the pins are backwards. This goes for your ESC's as well:
The pins marked M1 to M4 are connected to the 3 pin BEC plug from your ESCs. They follow the
same convention as the RX pins with the white wires connected to the inner pins, the red wires to
the center pins and the black wires to the outer pins
If you don't have the manual, I'd definitely go through it from start to finish again and set everything up from scratch as far as the board goes.
http://www.hobbyking.com/hobbyking/store/uploads/116867307X7478X23.pdf
