Kealan
Active Member
Hello so I think im having problems with connections between my tx and rx for my quadcopter. Its a turnigy tgy-i6 and tgy-ia6 receiver.
Basically the rx signal drops to zero and sometimes disappears off the screen on the tx at only a few meters distance but the quadcopter still responds to input.
I caught one of the antenna wires with a propeller a couple of months ago and bent it but it has flown at least 300m since then fine.
The last day i was flying (luckily hovering at about 8m) and the quad just lost all power and fell from the sky crashing.. It was as if it disconnected from the tx and went into failsafe and killed the motors.
The error on screen goes from 0% to 1% occasionally but the main problem is the rx signal going to 0 bars and flashing or else just disspearing completely along with all the other info regarding the rx on screen as if i had unplugged the lipo from the quad (which i havent)
I have tried re binding, and even today I cut the antenna to below where it is bent and stripped the protection and mesh off it to the correct distance for the wavelength but the same rx signal dissappearance is happening at only a few meters away.
Any help on this at all is greatly appreciated!
