I know nothing of amps and oms and.. whatever else. but this is going to be my hobby. I purchased this kit. And I need any general advice anyone can thing of, also, the esc says I can use battery 4s but the motor spec says up to 3s. Can I use a 4$ since it goes throu the esc first? Here are my specs of the kit I purchased.
ZMR250 Features:
100% Brand New and High Quality.
With compact portable design.
Arm plate thickness: 3mm
Main material: 3k Weave Carbon Fiber + fiberglass
Wheelbase: 250mm
Weight: 145g (not include the weight of metal fasten parts)
With rubber damper to decrease vibration during flight.
Aluminum alloy spacer, light weight, reliable.
Unassembled.
CC3D Features:
Powerful STM32 32-bit microcontroller running at 90MIPs with 128KB Flash and 20KB RAM.
3-axis high-performance MEMs gyros and 3-axis high-performance MEMs accelerometer.
Tiny 36mmx36mm 4 layer PCB for superior electrical noise reduction and flight performance.
Software support for Windows, Mac and Linux.
Direct high speed USB support with no drivers required, a truly plug and play device.
Spektrum satellite receiver support.
Futaba S-BUS hardware support.
Innovative Flexi-port technology for superior port flexibility.
4Mbits on-board EEPROM for configuration storage.
EMAX MT2204-2300KV Features:
Every single motor balancing test done
The propeller and motor mount cover using integrated molding process to ensure concentricity mounted paddle
Japan NMB bearings , low noise, long life
The choice of Kawasaki, Japan 0.2mm spindle , more efficient, less heat
The selection of high temperature NdFeB magnets
The motor of the pros and cons thread configuration, eliminating the multi-axis shot after installing anti- paddle security risks
Multi-axis multi- rotor brushless motor:
Low center of gravity design
Light weight Design
Long-endurance design
Spec:
KV: 2300
Max Trust: 440g
No. of cell: 2-3S
Framework: 12N14P
Propeller: 5" ~ 6"
Length: 32.2mm
Shaft: 3mm
Diameter: 27.9mm
Weight: 25g
EMAX Blheli 12A ESC Features
Features:
Use authentic electronic components to ensure high quality and enhance the current endurance ability of the ESC.
Based on BLHeli firmware,optimized for high performance with great linearity and much quicker throttle response.
Special designed for multirotors, and compatible with great linearity and much quicker throttle response.
Multiple protection featured including Low-voltage vut-off protection/ over-heat protection/ throttle signal loss protection.
Throttle tange can be configured and is full compatible with all receivers, providing smooth with all receivers,providing smooth,linear and precise throttle reponse.
All parameters can be programmed via using a program card or a transmitter,including default settings.
product specification:
Item:EMAX Blheli 12A
Continuous Current:12A
Burst current(10S):15A
Li-xx battery(cell):2-4
Dimension L*W*H(mm):40x20x8
Weight(g) wires Included:11
BEC Mode: Linear
BEC Output:1A/5A
Programmable:yes
ZMR250 4 Axis Frame x1
CC3D Flight Controller x1
EMAX MT2204 2300KV Brushless Motor x4
EMAX Blheli 12A ESC x4
5030 Carbon Fiber Propeller x4(2pcs CW + 2 PCS CCW)
Connection board x1
ZMR250 Features:
Wheelbase: 250mm
Unassembled.
CC3D Features:
Light weight Design
Spec:
KV: 2300
Max Trust: 440g
No. of cell: 2-3S
Framework: 12N14P
Propeller: 5" ~ 6"
Length: 32.2mm
Shaft: 3mm
Diameter: 27.9mm
Weight: 25g
Features:
BEC Mode: Linear
BEC Output:1A/5A
Programmable:yes
Connection board x1
