Hi. New to hobby, started with a toy drone through Groupon and learned a couple of valuable lessons... keep the drone in site, fly where there a no trees or buildings, beware of wind gust and finally, to quit trying to fly an indoor drone outside in winds (3 mpg is probably okay but anything higher and I'm chasing a fly away).
Just purchased a Bugs 3 (red) and decided to learn to fly, forget the heads up/return to home/taking pictures and movies. I've also resolved to only fly this at an open field....and not to let it get too far away.
Technically I'm ignorant. Hence I have a couple questions...if I have a battery that's 7.4 volts, c25 (?) and 1800 mghrtz and I increase the capacity (megahertz), do I get longer flight time? I've seen someone used a 5800 mghrtz (sure I'm butchering this) would I double/triple my time? I figure it's likely a bit heavier and perhaps a heat or life penalty with (brushless) motors that weren't designed to run for 25-30 minutes?
Secondly, the transmitter or controller...would a better controller extend my range and is there a a better controller I could purchase that would work with the Bugs 3 and anything else that I may purchase in the next couple years (inexpensive, more specialized, maybe a pocket fly, fly around, selfie drone and/or inexpensive GPS or Goggles to learn on) with the thought it could also be utilized with a hobby grade drone as I mature in my skills. It just seems that it would be easier to have something standard, that I can become familiar with and justify a bit more expensive purchase with a wide application and long usage life. Recommendations on a hobby class controller?
Ive read too that motors, even brushless, have a service life of only around 20 flights. Are spare motors something I should consider with the higher end toy drones or just plan on a "throw away"? At what point do you consider keeping a flight/maintenance log - or am I just being sillly?
Sorry about running on, got caught up in it for a moment. Thanks for any consideration or response.
Cobra54
Cobra54
