Newb Looking for advice on affordable micro/mini RTF
Honestly, i think you should get a popular model that you can buy spare parts for..Not all the syma "clones" share the same parts despite looking alike and, parts you will certainly need.
If youre going to spend the same money you may as well get the JJRC H5C CF or the Syma X5C-1...parts are abundant for those 2 models.
An example is the FY326 Q7 i want to get for a hybrid build..nothing but the looks are shared with the x5 but you can still get parts for it.
Also consider protocol which is the word used to describe how the flight board and transmitter communicate to one another...The syma uses a common protocol allowing transmitter upgrades which actually can give the syma better flight with adjustments you cant make with the stock transmitter.
The only 2 i recommend is either the syma or the jjrc model for that style quad.
I found out about them from the video I watched where they soldered a Spektrum cam and transmitter to a receiver and put it on a RC plane.
They have some very nice fpv set ups at reasonable prices..Im sure they will get my business in the near future.
The JJRC actually has some advantages right from the start..More powerful and a much longer range..Also consider its actually a few dollars less...The camera will be as equal to the syma if not better and, you can attach FPV to it just the same as you can the syma and, it actually be capable of handling the weight alot better from the more powerful motors.
I wont spend $50.00 for a quad unless its something custom im making but, Syma or JJRC are the way to go out of the box.
Ive never heard of Zozo or Zoza quads.. I would imagine he would say its better than a syma to make a sale..but, notice he uses syma as the comparison...thats because its so popular.
Google "parts for Zoza" or whatever the name was and see what you come up with.
I was thinking that too, it's just too risky
I was going to mention protocol, but couldn't remember the word, some birds and transmitters share protocols so as long as I have ones that share it I'm good, so do any micros and medium size birds share the same protocol, then I would only need 1 transmitter?
Thanks for the advice
You are finding out how nerve wrecking it can be to make a decision due to the numerous models available...welcome to the quadcopter club..hahaha.
I wont steer you wrong my friend...if you have done as much research as i have ,you would find my recommendations to be pretty solid.
Let us know what you decide and, youre welcome...Glad to have you onboard.
I hear ya
I must admit I got confused between the add on FPV and the 808 keychain cam. I understand now that the FPV cam just like the stock cams takes 2.0 mp photos and 720 video and is controlled by the transmitter, however the 808 keychain cam only takes 720p video and no stills and is manually controlled, is that about right? BTW I'm just starting to figure out that the JJRC H11D with FPV, is the Syma FPV kit?, the difference is that the cam lense can be remote controlled up and down, I don't understand how that is possible, if it's the same FPV kit cam, does the cam have a receiver that can control it with certain controllers? What's also appealing about this one is the controller only takes 3 AAAs motors you don't have to solder they have clips, how does it stack up to the H5C CF motors though? Here's some good and bad things being said about it. http://www.rcgroups.com/forums/showthread.php?t=2489964
That is pretty much a new model from JJRC...from what i understand the range is not that great on this jjrc model and thats a shame as they usually have great range...I read the antenna was 24mm which would make it less than 1/4 range which is not a good thing...This model seems to have issues...A full 1/4 range should have a 31mm antenna wire on the flight board..I suppose the range issue can be fixed but its a fail out of the box for JJRC on this one
The remote tilt is a first for a "toy" quad...There is a motor that moves it up and down via a switch on the radio...On a hobby quad this would be called a remote gimbal and, i suppose you could call it that for the JJRC as well but its just pan up and down and no left to right.
I wouldnt purchase this model at this time..Consider it a beta test model which has already failed but expect issues to be fixed by JJRC on a new model to succeed this one.
You are correct about the 808...you turn it on before flight to record which isnt such a horrible thing considering the better quality they provide...Not all "advertised" 720p cameras are of high quality...Actually most all the 2mp toy cameras are 720...None are better than the 808...Some are even advertised as 1080p like the mobius and are horrible....The mobius is king of the enclosed portable cameras at this time...just too heavy for a smaller quad.
I cant comment much on the motors as i dont know enough about it just yet...It seems jjrc is innovating another feature which time needs to test.
The syma FPV kit is controlled all from the radio of the X5C-1..one button takes a still picture while another one turns the video on and off.
3 aaa batteries in a transmitter is weak to say the least.
I still suggest the H5C CF or X5C-1
If you want a larger quad, i suggest the Syma X8C.
Once again Mike I can't argue you with your logic, I have been reading that it's fairly new and has flaws and the fact that it can't pan right or left is a big drawback, then again if someone wants to have that ability they should consider a quad that can handle a gimbal, as for the motors, while it's sure innovative, I have yet to find out where you can get them, so how good is that? So it looks like I have it narrowed down to the H5C CF or X5C-1 at least for that size. I appreciate all the good insights.
As with most all new models it might take a few months before suppliers can stock parts for them..It took almost 4 months before parts for the FY326 was even available.
Despite the remote gimbal not being able to pan left or right, the excitement here is, that a remote gimbal of any sorts has made its way onto a toy quad at such a low price range...In time we may see full remote gimbals and brushless motors and better quality fpv and cameras installed on toy quads.
Right now the 7.4v quads are the power houses capable of carrying full FPV systems.
What i wouldnt mind seeing is brushed motors in 540 size like used in RC cars and boats but they are a bit heavy and draw alot more amps than the toy flight boards are capable of at this time.
I already have a new dream hybrid quad in mind.:rolleyes:
TARANTULA X6 or DM 007 body
JJRC H11D flight board with SYMA X8C motors (7.4v) with x6 props or DM007 props
JJRC remote Gimbal.
FPV hobby FPV system (200mw)
1500mah 2s lipo
Range mods to JJRC board and Transmitter. (200 meters plus, range.)
:p
JJRC remote Gimbal.
1500mah 2s lipo
:p
Sounds intriguing, just wondering how much the total cost would be VS. say a CX20 or other gimbal capable quad?
Kind of got the idea that this was a first, the guys on rcgroups really tried hard to mod it to make it work right, but to no avail, if it doesn't work out of the box, most people will not bother, what about UDI any good with that company? I wonder if any other companies are going to copy the flight yoke controller they make. I'm sure It really appeals to pilots and armchair pilots like me
Any idea what the resolution is?
Ya know. Until you asked I wasn't even curious. All the videos I've seen look good so.............. Now that you asked I haven't found anything in the manual or on the manufacturers site that says what the resolution is. As long as it works and the video looks as good as the Youtube examples, I don't really care what the #'s are. When the weather breaks here and I get a little more time on the Syma I'll install it and see.
Yeah, the reason I asked is because I searched and couldn't find any resolution specs either. I must admit for something that tiny it does look fairly decent.
Get this, latest scambay UDI U818s or is it a Syma Xc5 can't tell lol, cx20 and Phantom and Inspire.
$16.99 lmao. This time they even tell you they are in China, I don't think it's a hijacked account this time, just blatant everyday ecrap scam.
Here's a link just for laughs. http://pages.ebay.com/link/?nav=item.view&alt=web&id=171978251237
look how they can't even get it straight on what it is lol.
Pretty much i would forget anything that is wifi untill ALL of them figure out the signal bugs if thats even possible...Even we lose wifi signal via internet...its just going to happen.
To men this leaves me wondering what day the internet wants me to lose my toy quad.
Yea, those prices on that ebay link are BS..maybe hes selling just the manuals..hahaha.
That hybrid i want to build would be around $50.00 without the fpv and around $150 or so with it.
UDI is a known company..theyve been around for some time since the beginning of the toy quad movement as syma and WL toys has been.
Im not up to date on what they are offering so cant give much insight to them just yet.
By the way..the CX20 is pretty much a hobby grade set up..ive seen them for $239.00 some where...Just alot to know about setting up programming and all that jazz.
I have no doubts WL Toys or SYMA will come up with something thats more hobby grade in the near future.
