Mike H.
Toy Quad Builder
The X9 is super lightweight clone of the Blade nQX...It uses small 6mm motors as does the blade and is actually not far off from the performance of that $100.00 blade...This is one i have coming as it gets very good reviews and is said to be a very good indoor flyer...the bayang is considered the best clone of the Blade model...Parts are extremely cheap to make repairs on this model.That reminds me, how important do you guys think a brushed motor is VS. brushed? Just checked out a video review of the Bayang 9, nice but only 5.5 mins flight time no way you could mount a cam on it at least I don't think there is, the guy said its a clone of another model, can't remember which?
I think you mean brushed vs brushless?
Two complete different worlds in cost and reliability...Brushless is what the hobby grade industry uses and these can get very expensive..Brushless motors are used on DJI's and other high dollar quads...they require seperate electronic speed controllers for each motor and usually use a 2s lipo or stronger to power them...Certainly not something you want to run into someone with by accident.
To add more about the bayang x9..It uses a small 150mah battery...the entire quad including battery is less than 20g in weight...some are using 200mah batteries to improve flight time to just over 6 minutes.
The syma X5C without the prop gaurds and camera and landing gear usually gets around 6 to 7 minutes (Almost 8 minutes with a 750 mah battery) with the stock 500 mah battery and just under 4 minutes using the camera and with the gaurds and landing gear attached...the camera uses the onboard battery for power as well so this takes away from flight time.
With a keychain camera such as the 808, it has its own battery so, flight times usually increase by 1 minute or so...Some remove the camera from the case to lose some weight.
The average flight times for most all these toy quads are typically 5 to 7 minutes.
