Need help with setting up arm switch
Pyrzi
Hi,
I got my first fpv drone setup. (Eachine wizard and FlySky i6) My quad is ready to fly but I have issues with arm switch. I did every step as guided in this video:
but when I arm my quad my motors won't start running. They only start when I increase the throttle and when I give zero throttle it will turn off the motors which makes it super hard to fly.
Anyone know what I have done wrong or what I need to do to fix this?
Thank you!
My quads use APM flight controllers which permits one to choose to have the props spin or not when the motors are armed. I don't know if you have that option or not, but you might want to check what configuration choices you have.
I also noticed that when i give just a little bit throttle all the other motors start spinning except one (back left). It starts spinning when i give more throttle but the wires that are connected in the middle part of the wing gets very warm. Even though I haven't took off yet. All the other motors are cool. Guess I am not going to fly anytime soon...
Thx for the tip. I'll go through my configuration choices but I would assume that if it needed to be turned on, it would been told in the guide video.
You should be able to go into the i6 TX and tweak your range (End points). Ch3 is throttle, tweak the first # till it no longer cuts out the motors when the stick is at the bottom.
