My first build it yourself build.
Dragonringki
I have done a ton of research and i have spent some time with a friends drone and i have my heart set on the dji f450. I am based in the south of the uk.
However gathering everything i need seems to be 'part of the fun' proving tiresome.
First of all what is the reputation of drones direct.
https://www.dronesdirect.co.uk
Secondly for a setup for basic flying will this all be sufficient.
F450 bundle
http://www.dronesdirect.co.uk/p/6958265103070/dji-f450-complete-bundle
Radio stuff
http://www.dronesdirect.co.uk/p/spm...-transmitter-with-ar8000-rx-and-free-ar610-rx
Lipos
http://www.dronesdirect.co.uk/p/b-20c-2200-3s1p-eco/gens-ace-2200mah-3s-11.1v-20c
Charger
http://www.dronesdirect.co.uk/p/4301075/vonista-80w-battery-dcac-charger
Landing gear
http://www.dronesdirect.co.uk/p/450-landing/f450-f550-landing-gear
The reasoning for the landing gear is i eventually will be using this for photography but also for fun/speed. Whixh is why i chose the f450.
Any advice is welcomed as im very new to this world of building your own :) and even better if anyones knows a shop in the south i can go and pick this up from
Your listed supplier for the F450 bundle states: "Complete Bundle", but (and unless I'm missing something) there doesn't seem to be any mention whatsoever of motors or ESC's? Are they actually included??
All I see is the frame itself (which includes power distribution PCB), and the flight controller/GPS module… not quite what I might understand to be a "Complete Bundle"
Thanks
Il keep looking then. If anyone knows of a reputable supplier in the uk id really appreciate a point in the right direction
Well, not so fast! The kit you found includes what I understand to be a pretty darned good FC… I can't comment on the relative competitiveness of UK pricing (We moved from the UK to Canada 15 years ago - I'm not 'up' on the strength of the GBP any longer!). Perhaps consider pricing it out from the same vendor with your choice of motors & ESCs to see whether it's still within range of your anticipated budget?
As an example for strictly comparative pricing purposes (I too am a complete noob, so please don't take any of the following as 'gospel', or as a "certified config"… let those with far more experience/knowledge than I help guide you there!)
Hobbyking offer a 'plain' SK 450 chassis for ~$20USD, onto which you'd need to add your own (and I quote):
4 x 28mm 1000~1200kv (or similar size/kv)
4 x 15~25 Amp ESC
4 x 8x4~10x4.5 Prop (2CW & 2CCW)
1 x HobbyKing Multi-Rotor Control Board
1 x 1500~2200mAh 3s 11.1v Lipoly battery
Your own radio and 4 channel receiver
They sell the Naza M-Lite FC with GPS for $169USD
They (HK) recommend 28mm motors on their frame, so a set of 4 motors with 20A ESC's would run around $86USD.
Don't forget to consider any shipping & import duties.
