Mjx bugz2 battery
Hi hope someone can help me with this issue i have a bugz 2w and with standard old battery im getting 4/5 minutes tops after crashing my bugz4 in the sea i used the bugs4w batterys witch are alot newer and gave 14 plus min in the b4w in my bugs 2wvstill getting same 4 to 5 minutes so newer 3600mah battery gives same flying time as old 1800mah must be problem with the drone????
Actually, it wasn't helpful. That's mostly because I don't know. I have no experience with that machine nor that battery. Hopefully another member can help as soon as one chimes in.
Because i didn't need to look for a upgraded battery on ebay i have 3 x 7.4v 3600 mah 25c thats is why i said im getting the same 4to5 minutes as the stock battery
I have a MJX Bugs3 and Bugs 3 Mini. Both still give me more than 10 min of flight time, and I have them for more than 3 years.
MJX Bugs series has enjoyed good reputation among drone users. Unfortunately, it appears you have a defective one.
Yes. in my opinion, the culprit is your b2w. You have no issue with your b4w, right?
Is this a recent purchase? Is it too late to return for refund?
P.S. Please don't take it the wrong way, but what you wrote would be a lot more clearer to read if you used the punctuation marks to separate the sentences. No offense intended.
