MIX Bugs 2 camera issues
Depending on what other 1S batteries you have, I would consider just changing the connector on the TX03 to a Micro Losi style. Those are very common and you can get batteries anywhere cheap.
Jackson already posted a link to a Mobius cam that would be much better for what you want, in that case. Look on the first page of this thread.
Hey, fairly new quad owner here. Purchased an MJX Bugs 2 a few months back, and I could not be happier with most of the features I bought it for, such as the GPS hold and telemetry display. However the camera, which only records to an onboard micro usb, stopped recording halfway through it's first flight. There was no crash, no water damage or anything, and I have tried multiple micro sub cards but it will not record. Does anyone have any advice?
I have a Bugs b2c. The first time I used the camera it worked great. I recorded 4 videos. The next time I tried to take a photo or video I could not. I put the micro SD card in my computer and looked at the directories on the card and found 2, photo and video. I decided to delete the 4 videos from the video directory and then try to use the camera function again. I had mixed success. I was able to take either a photo or a video, but only one and then I had to go back and delete that file from the directory before I could take another. This was proof to me that the camera works and the problem is with the micro SD card. Unfortunately you cannot just go and buy another card because the original card has hidden files on it which I believe somehow control the camera function. I have tried to reach someone at MJX for technical help, but so far no luck.
Has anyone solved this issue? I'm having the exact same problem. Sad part is, the thing really does fly well. But, with no camera, who wants it?
Im having the same problem. Did ever get it
