Mighty Midget 3-6s Long duration Flying quad. (1 Hour of flight)
FLoHIO117
The Mighty Midget is a long duration flying quadcopter that has many built in features. This quad is capable of flying a very wide variety of batteries. Anything 3s-6s will fly this quad. The mighty midget is made to carry a wide variety of batteries, FPV and AP setups. It has mounting holes to mount a dji H3-2D Gimbal, and a Tarot rail system so that you can add a Tarot Gimbal or other accessories.
This frame combines the best of all worlds. It is foldable, light weight, well thought out, and replacement parts will be available. Before this frame if you wanted to fly for more than 25 minutes you pretty much had to build a stick frame that was custom made. So if you wrecked it, it normally wasn't fixable. It also didn't have any room for multiple gimbal options and fpv gear. This frame lets you add all standard fpv gear a go pro, and gimbal and a wide variety of batteries and fly for longer than normal amounts of time. also if you wreck it you can easily buy a replacement part to fix it which is a huge advantage compared to a custom frame.
This frame was not designed to compete with the long duration flying quads! It was designed to give the best of all worlds, Flight times, Size, and Functionality.
Features:
*Light weight all carbon fiber frame
*Foldable
*Dji H3-2D gimbal mounting option
*Tarot Rail system mounting option
*2-6s ESC's
*4 Different battery mounting Options
*Clean construction with minimal wires exposed.
*Low profile Detachable landing gear
*Room for all typical fpv gear
The arm lengths are offered in 3 different sizes. small medium and large.
*small will fit a 10" prop max
*medium will fit up to 15" props max
*large will fit up to 18" props max
((Flight times)) that have been done so far with the heavier G-10 prototype I have done are:
Each flight had a 79 gram watt meter hanging from it which was dead weight, so without it flight times would have been even longer. Also final version which is carbon fiber will be lighter helping flight times.
An hour or more is deff capable.
*2x 6s 6800mah Li-Ion packs in parallel 1 hour and 40 seconds
*6s 6800mah Li-Ion pack 46 minutes on a windy cold day.
*4s 10,000mah Li-Po pack 38.5 minutes
*4s 5,000mah Li-Po pack 17 minutes
*4s 5,000mah pack with 425 grams of dead weight added 21 minutes
*3s 10,000mah Li-Po pack 37 minutes
Videos:
More videos and pictures will be up as soon as I get the final version cut and put together.
If interested in a frame PM me for pre-order options.
HI mate glad you came on board this forum , that will save me so work lol , What i will say to any one reading this, FloHio117, is a GOD OF QUADS
and a really nice guy his video of clouds and cows is in the "so you want a multirotor" beginners section , he spends a lot of time in working out and testing the best builds, and will help getting the system you want and more in your hands to fly , Thanks for coming onto this forum
Interesting. Any footage on the actual product and the features such as the folding mechanism or the battery mounting options?
Hi mate if you message FloHio117, he will help you ,he is a really nice guy , just go to the 1 hour hover thread and click on his avatar you will be able to message him
The Mighty Midget, what a name! ha. Looks great though and you can see the power when the guy is flying indoors on the video.
