Michael Fenimore
Firstly, if this is in the wrong place, please move it.
My subject is kind of broad. Here's my situation; My Syma X5C-1 USB battery charger seems to be failing. In the beginning, about 15 or 20 charges ago, it would charge the battery and shut off the LED to indicate it was done.
Now, the past 3 charges, the light stays on for about 5 hours or more.
I allow the battery to reach room temperature at all times before charging. Rest periods after flights is never less that an hour.
Anyhoo...
Today I pulled out my iMax B6 charger. Plugged in the battery, set all parameters (.5A, 3.7v) and started a charge cycle. The battery charged to 4.2 volts and .5A as expected in about 54 minutes.
DVM shows 3.9v 30 minutes after charging. So I'm going to guess (and cross my fingers) that the battery is still OK but the USB charger is being erratic.
I have other batteries on order, but they seem to have found that proverbial "slow boat from China."
They should be here next week.
So, am I doing this right? Should I consider using the iMax B6 to charge all my batteries?
Any input is greatly appreciated.
Your noob in service,
Mike
Anyhoo...
Mike
