Rudix
Hello there and thanks for reading this.I bought a jjrc h8d and it came yesterday.I am not a pro with quadcopters,it's my first quadcopter and all the stuff,but I looked a little bit on the internet and got some info.So I made the unboxing and as I said with the info collected I knew that at first the propellers must spin freelywhen you push them.I tried this experiment and the left one from back had some "brake" and it's very visible when you push the throttle and then pull it to 0 , the other 3 spin when this one is stoping very early.I tested it on a flight and it really tends to fly backward even from the landing(it's like there is some weight on the back draging it) and it's very uncomfortable to fly because you have to push it continously forward to keep it straight and you can't record because it's shaking too much and I thought that the motor can be faulty.I will post a photo of what the seller said.Thank you very much!
