Is my planned build any good?
Hi mate get the KK flash tool so you can flash it to a better code, multistar motors work better on an ESC flashed with blheli but are harder to find 30amp ones but they do a programmer so you can flash them
go for the bigger prop size but carbon fibre,as this will not be the lightest due to its size and nylon props will snap from stress
http://www.hobbyking.com/hobbyking/...ropellers_11X4_7_LH_and_RH_Rotation_Pair.html
seeing your looking at hobby king this frame is better and cheaper
http://www.hobbyking.com/hobbyking/...ng_Quad_Copter_Carbon_Fiber_Version_Kit_.html
Thanks for the recommendations, ill definitely be looking at the flash tool and those props look like they could be a winner. However when i first started planning this build i looked at that specific frame but it was being a reviewed as flimsy and breaking easily when landing, the on i linked above has a stronger build and stronger landing gear :)
OK mate not a problem I just watch out for companies that buy from hobby king then add a mark up and sell on , In that case your better to buy from hobby king first off
Hi mate you need the the usb programmer I linked on here thats for the ESC
Then you need the Flash lead for the KK
