Hello people, I got the urge to build me my first drone.
I have a walkera 250 and now I have the desire to build me a drone everything alone.
I made a list of everything I need and I wanted to know who is responsible if what I choose is fine and if possibly, I need nothing else.
Objects in my possession at the time
Propellers
I have DEVO 7 (the walkera)
Two lipo from 2800 to 30c
One lipo from 2200 to 25c
Skyzone v2 40CH
Objects I need
SM-ZMR250-250MM-Carbon-Fiber-Frame-Kit-with-5mm
Frame like this and aesthetically looks very durable
Matek-LED-POWER-HUB-5in1-V3-Power-Supply-Board-BEC-5V-12V-Low-Voltage-Alarm-Tracker
Power board seems very complete and has reeds the buzzer for a low voltage, or if you lose your drone
Emax-Skyline32OSD-Skyline32-Advanced-Flight-Controller-with-OSD
Fc seems to have everything and a fair price; I would like to play around by setting the various modes
This has compass and cheat over support for GPS and the OSD on the screen
EMAX-BLHeli-Series-20A-ESC
How esc I chose four of these, they should also have the right as an one-shot technology? Amper 20 with support 3 to 4-cell battery
Eachine-Falcon-250-2204-2300KV-CW-CCW-Motor
How 2300kW engine with support 3 to 4-cell battery
Eachine-800tvl-CCD-110-Degree-FPV-Camera-lens-w-5_8G-600mW-Transmitter
This is the camera, 800 line horizontal and take it in PAL format so that you have more vertical lines.
Walkera-HM-DEVO-RX1002-W-Devention-10CH-2_4GHz-Receiver-White
As this receiver has 10 channels, my question is written, which is compatible with the devo 10 but I have the 7. Is it compatible?
Obviously, I know if you will use only six channels instead of 10, right.
As needed to mount thing it is that I cannot do without, and that I need?
Type a welder? Which?
The wire that thick?
What other material do I need?
Moreover, this GPS is compatible with my FC?
N32-GPS-For-Mini-NAZE32-Flight-Controller
Eventually I would like to build me a nice drone with many functions, durable. With the possibility of including batteries 3-4 cells and also put the GPS and be able to connect it to your cell or tablet with Android.
Thanks in advance for all the advice
Propellers
Skyzone v2 40CH
Objects I need
