agridronedesigner
When flying in Auto mode, you might run into obstacles like poles or trees. If that happens, you can manually fly around them using the Flight Assistant app.
The drone will automatically stop and hover when it detects something ahead.
It’ll switch to Projection Point Mode, and you’ll see three options on the app:
Breakpoint, Return Point 1, and Return Point 2.
What to do next depends on the situation:
If you accidentally move the sticks, just tap Breakpoint. The drone will go back to where it stopped and keep flying along the original route.
If it’s just a small obstacle, you can fly around it manually, then tap Return Point 1. The drone will slide back to the route at that point and continue spraying.
If there are too many obstacles ahead and it’s not safe to keep going, tap Return Point 2. The drone will move over to that point on the route, adjust its heading, and then continue the job from there.
Super simple—and really helpful when flying in tricky environments.
