How to Connect an ESP32 with a Laser Rangefinder Module for Drone and Robotics Projects
Mayer.xiao
Laser Sensor Solution
How to Connect an ESP32 with a Laser Rangefinder Module for Drone and Robotics Projects​
If you're building an autonomous drone, a small ground robot, or an obstacle avoidance system, an ESP32 paired with a laser rangefinder module can provide reliable distance measurements while keeping power consumption low.
Compared with ultrasonic sensors, laser distance sensors offer longer measuring ranges, higher accuracy, and much better performance under outdoor lighting conditions. In this guide, I'll show a simple way to connect an ESP32 to a UART laser rangefinder module and read distance data for your own projects.
Why Use ESP32?​
ESP32 has become one of the most popular development boards for DIY robotics because it provides:
  • Built-in Wi-Fi and Bluetooth
  • Multiple UART interfaces
  • Low power consumption
  • Easy programming with Arduino IDE
  • Large open-source community
For many UAV and robotics projects, it has enough computing power to collect sensor data while communicating with a flight controller or cloud service.
Hardware Required​
You'll need:
  • ESP32 development board
  • UART laser rangefinder module
  • Jumper wires
  • USB cable
  • Optional breadboard
The laser module should support TTL UART communication. Most industrial laser distance sensors provide continuous measurement mode and serial output, making them easy to integrate.
Wiring Diagram​
Typical connections are straightforward.
Laser ModuleESP32
VCC5V or 3.3V (according to module specification)
GNDGND
TXRX2 (GPIO16)
RXTX2 (GPIO17)
Always verify the operating voltage before powering the sensor. Some modules use 5V power while UART logic remains at 3.3V.
Arduino Example Code​
Using HardwareSerial makes communication simple.
Code:
#include <HardwareSerial.h>
HardwareSerial LaserSerial(2);
void setup() {
  Serial.begin(115200);
  LaserSerial.begin(115200, SERIAL_8N1, 16, 17);
void loop() {
  while (LaserSerial.available()) {
    char c = LaserSerial.read();
    Serial.print(c);
Your module may require a command to trigger measurements or enable continuous output. Refer to the communication protocol supplied by the manufacturer.
Testing the Sensor​
After uploading the sketch:
  1. Open Serial Monitor.
  2. Point the sensor toward a flat object.
  3. Move the target closer and farther away.
  4. Verify that distance values change smoothly.
If no data appears:
  • Double-check TX/RX wiring.
  • Confirm baud rate.
  • Verify power supply voltage.
  • Make sure the module has entered measurement mode.
Applications in Drone Projects​
An ESP32 combined with a laser rangefinder module can be useful for many UAV applications.
Altitude Measurement​
Measure low-altitude height during landing or hovering where GPS accuracy becomes limited.
Obstacle Detection​
Detect walls, trees, poles, or indoor obstacles during autonomous flight.
Payload Positioning​
Measure the distance between a drone and a landing platform or delivery target.
Ground Robots​
The same hardware setup also works well for AGVs, warehouse robots, and indoor navigation systems.
Improving Measurement Reliability​
A few practical tips can improve performance.
  • Avoid measuring transparent surfaces.
  • Keep the sensor lens clean.
  • Reduce vibration when mounting on drones.
  • Use averaging or filtering for smoother readings.
  • Ensure sufficient power during wireless transmission.
Choosing the Right Laser Rangefinder Module​
Different projects require different specifications.
Consider:
  • Measuring range
  • Accuracy
  • Measurement frequency
  • Interface (UART, RS232, RS485)
  • Module size
  • Power consumption
  • Outdoor performance
For compact drones, lightweight modules are generally preferred.
Final Thoughts​
Connecting a laser rangefinder module to an ESP32 is surprisingly simple and opens the door to many robotics and UAV applications. Once the UART communication is working, integrating the distance data into navigation, obstacle avoidance, or automation logic becomes much easier.
If you're looking for more information about compact industrial laser distance sensors or need communication examples for ESP32, Arduino, or Raspberry Pi, you can find additional technical resources here:Laser Distance Sensor -Laser Sensor Solutions-Meskernel
The documentation includes interface descriptions, communication protocols, and integration examples for various embedded platforms.
