Help
Ryderfpv
Please help I’m using dx7 v2 and orange rx satire Receiver and tyro99 with tyro129 board in beta flight, when I arm it flys up when I check beta flight it says the throttle is fine and if I try to arm with the throttle above zero it won’t arm until at zero but once at zero it flies up I want to fly the drone more so please help
Try to break down what you are doing step by step. If you can share screenshots of what you're seeing and/or video of what you're experiencing as is kinda hard to guess. Sounds like you have binding/protocol selected in betaflight and all sticks are controlling the right sliders/showing the correct values in the receiver tab (minimum of 1000 and maximum of 2000 resting with sticks centered at 1500). If your quad supports its suggest turning on BlackBox logging as well and do some testing with that turned on then take a look at the log files (download using betaflight configurator and open them up using the "Betaflight Blackbox Log Viewer" app)
