First build, can you guys look at my parts list?
Quadcopter stuff:
FatShark Teleporter V5 FPV Kit:
~TeleporterV5 Headset
~SpiroNET circular polarized antenna for headset
~FCC transmitter with SpiroNET circular polarized antenna
~700L CMOS Camera
~7.4V battery with battery charge adapter cable
~Zipper Case
http://www.amazon.com/dp/B01BWO29PQ...UTF8&colid=YEFBIHTQBPUX&coliid=I3DRCA1IOBKZVI
Tenergy 1-4 Cells Li-PO/Li-Fe Balance Airsoft Battery Charger
http://www.amazon.com/dp/B004FGWY54...UTF8&colid=YEFBIHTQBPUX&coliid=I3G8UVTRL0SPF7
Floureon 2 Packs 3s 11.1V 3000mAh 30C Lipo Battery with Dean-Style T Connector for RC Airplane Helicopter Car Truck Boat
http://www.amazon.com/dp/B00L2V09VQ...UTF8&colid=YEFBIHTQBPUX&coliid=I3FA8BAG7Y8HK2
Crazepony® GemFan 5030 5x3 CW CCW Glass Fiber Nylon Propeller for Mini QAV250 Quadcopter Multi-rotor (8 pairs)
http://www.amazon.com/dp/B00Y4QNSFA...UTF8&colid=YEFBIHTQBPUX&coliid=I3A8HXAHFVCONM
HI 250 mm Quadcopter Race Copter Frame Kit:
~1 x 250 mm V2 carbon frame kit
~4 x MT2204 2300KV Brushless motor
~4 x Emax simonk 12A ESC
~8 x 5030(CW+CCW) 2-blade Propeller
~1 x CC3D Flight Controller & protect case
~1 x Power board
http://www.amazon.com/dp/B010FMGUS8...UTF8&colid=YEFBIHTQBPUX&coliid=I2CWPT37TP86ME
GoolRC Flysky FS-i6 AFHDS 2A 2.4GHz 6CH Radio System Transmitter for RC Helicopter Glider with FS-iA6 Receiver
http://www.amazon.com/dp/B00VE3PZ3Y...=UTF8&colid=YEFBIHTQBPUX&coliid=IJHQ9U1VWRML4
Integy RC Hobby C23212 LiPo Voltage Checker + Warning Buzzer
http://www.amazon.com/gp/product/B0...rd_t=36701&pf_rd_p=2437869762&pf_rd_i=desktop
Tools:
Elenco TK14 Electronics Technician Starter Kit, 9-Piece:
~SR1N - 25 watt soldering iron with stand
~ST2 - 5" needle nose pliers
~ST3 - wire stripper
~ST5 - 3/16" slotted screwdriver
~ST6 - #1 Phillips screwdriver
~SW3 - disorder wick
~LF99 -Lead Free Solder
~ST23 - heat sink.
http://www.amazon.com/dp/B0002IWF62...=UTF8&colid=YEFBIHTQBPUX&coliid=I6QQTP96OJUAW
Elenco Soldering Iron Holder
SE MZ101B Helping Hand with Magnifying Glass
ZJchao Precision Prop Balancer for Quadcopter and Airplane Props
T-Trees 10 Pairs Of Xt60 Xt-60 Male Female Bullet Connectors Plugs For Rc Lipo Battery
Anytime Tools 127 pc Heat Shrink Wire Wrap Cable Sleeve Tubing Sets Assorted Size w/Case
iFixit Portable Anti-Static Mat (This is for future electronic builds as well as the quadcopter)
iFixit Pro Magnetic Project Mat (This is for future electronic builds as well as the quadcopter)
How does this look? Everything compatible before I pull the trigger on this build?
General advice or tips?
Edit: Added the battery buzzer
Quadcopter stuff:
~700L CMOS Camera
~Zipper Case
~1 x Power board
Tools:
~ST23 - heat sink.
If your batteries come with deans connectors, you should get deans connectors not xt60, unless you plan on swapping the ones off the batteries. Personally I prefer xt60
Quadcopter stuff:
~700L CMOS Camera
~Zipper Case
~1 x Power board
Tools:
~ST23 - heat sink.
And while that teleporter kit is nice because it comes with everything you need, from what I've heard you'll be disappointed in the goggles. They will definitely get you in the air, but also leave you wanting more. And the battery buzzer is cheap and simple, but if you plan on going all out you should get an osd that will display your battery voltage
Sorry, I'm a pretty new to all this, you mean a osd on my flight controller? On what part exactly should the battery voltage be displayed?
You can get them that do a whole range of things, if you want just voltage the osd module will go in line with your camera, vtx, and battery. There's a whole load of youtube videos and forum posts outlining how to do it
