F11s controller factory reset
Hi David, Yes, I've tried both combinations of old with new. As there is no change from "Connecting', it doesn't look like anything is resetting the controller (or drone), it's just looking for it's known (previously paired) counterpart.
RE : I actually bought the second of these drone & controller recently
Does the 2nd controller pair with the 2nd drone.
Hi, dunno if you still are reading this thread, but i want to add that you didn't get the right version of the control, the model f11s pro 4k, has the type v1 wich is the oldest, v1.2 and v1.3, and they are not compatible between them, also comment that i have a similar problem on my drone and i am guessing is the wifi module, so i bought a new wifi module, will see what happens when i get and replace it, will post results.
Thanks varo, I'll be interested to know how that goes for you. Is yours a F11s?
yes, mine is the f11s pro 4k, v1, i have purchased some parts for it in aliexpress, and when i've done it, i had to be sure about the model, all the f11s pro 4k look the same, but the hardware inside is a little different dependind on the version, v1, v1.1, v1.3, v1.5 as i mentioned before, so my guess is that your remote is a different version than your drone
if you open the drone, and the fly board is green is the first version, if is blue or red y will be another version.
