I have the quad-copter attached to a test harness, tried to get the quad just off the ground for testing. Was at aprox. 50% throttle when I noticed a motor slow down and the ESC LED connected to that motor turn red. After returning to zero throttle, I then tired 50% again and the ESC caught fire.
No soldering was done. I bought connectors for ESC to Lipo.
The point of the Quad was to lift a payload (only for 5 minutes and does not need to get far off the gound). The test done DID not have an extra payload on it when it caught fire. During first test, realized the extra mounting screws on the motors were causing two motors to stutter (touching coils?). Replaced them with correct size/smaller screws. The motors that stuttered were NOT the one attached to the ESC that caught fire. Tried this same configuration on an old frame a while back and the quad would drift/flip on take off but no ESC caught fire. Scrapped that frame for this new Iron man one.
Not sure if the Props are too big for the motors? Or should I up the amp to 30 on the ESC? Or is this just a case of a bad ESC? All oher ESC were not hot after incident.
Any help is welcome!
View attachment 2570 View attachment 2571
Quad-rotor Specs:
Tarot Ironman 650 Frame
Venom 5000 mAh 35C/60C Lipo (3S1C)
Afro 20 Amp ESC
Turnigy Multistar 2216-800 Motors (800 rpm/V)
APC Electric E 13'' x 4 Props
Turnigy 9x Transmitter Reciever
KK2.1.5 FC (Stevies newest)
A little more background:Tarot Ironman 650 Frame
Afro 20 Amp ESC
