Eachine VR D2 Pro Upgraded Open Source 5" 40CH 5.8G Diversity FPV Goggles w/ DVR Lens Adjustable
Feature:
New Logo, New Design
Upgraded Open Source Receiver, increases the sensitivity of receiver
Auto search, you can search all frequencies around or select your own frequency to avoid interference
Add the power indicator function instead of the built-in buzzer, you can check the power on displayer directly.
With white noise and snow screen
Dual receiver to get strong and steady signal
Support Lens Adjustable
Support upgrading
Built-in DVR function, record every wonderful moment and play back
With comfortable face sponge
With accurate capacity, 7.4V 2200mAh Lipo battery consists of 2 x 18650 battery
Support one key into power saving mode
Specifications:
Screen size: 5 inches
Screen resolution: 800x480
Frequency channel: built-in 40CH 5.8GHz receiver
Battery : 2S 7.4-8.4V Lipo battery
Battery work time: 2.5-3 hours
Operating current: 600--680mA
Receiver sensitivity: -95dBM
Antenna connector: RP-SMA
DVR Max Support: 64G TF Card
Goggles weight: 285g (without antenna)
Antenna weight: 29 g (Flat: 13g, mushroom: 16g)
Dimension(mm): 150 X152 X96 (without antenna and antenne mount)
