Eachine 4x3D a mini quad that flys inverted
Well guys Eachine , Has stepped up the action of the mini quadcopter with this 3D quadcopter
Whats new, well this quad is as well as flips and rolls it will fly inverted , Yes all you guys that want a mini to fly real 3D
This quad Flies more like the bigger quads this is the one to get , Its bigger then the other quadcopters from Eachine due to the longer arms it has built in prop guards , still has the 6 axis gyro 3 rate setting
20% 60% 100% flight modes , Smart mode so even if its nose in will follow stick commands , then
There is the full 3D mode this will give you the flips and rolls like the G022 but now you can fly INVERTED
Binding is different too ,power up transmitter then power up the quad , move throttle to full then to zero the props will kick , and now your ready to go , you can flick between flight modes and even switch the LEDs on and off
She is fast , and very impressive in flight the inverted takes some skill to master , but this is what the hobby is about, master the beast
The battery charges from the USB lead it comes with, and will be full in 60 mins or less , most mini quad batteries will just pop in the Belly of this lovely toy quadcopter
She comes in a nice box, well packed in trays so you can store the quad without damage spare blades, charger lead , battery, transmitter , and a good instruction manual , but if you flown a mini quad your be at home with this great 3D flyer for Eachine.com
