Hello.
I have a DJI Phantom 3 4K and im getting "compass error exit p-gps mode". I have done IMU calibration, is that the correct way to calibrate compass? When I did that I was on an open field with no metal.
But when i have scrolled around the forum I have learned that the cable connector to the motherboard can come loose. When I get the error it switches back to normal within a few seconds and it's often when I do a fast turn och go up in altitude or down fast.
Is there any other way to calibrate the compass or any other solution? or should I open it up and check the cable connector?
Best Regards /Christian
