CX20 Auto Pathfinder (6 Axis)
Shuff
Hi All
Just been given a CX20 (Zero Tech ).
I am looking for some info on the flight controller ie what type is it ?
The previous owner disconnected the 6 pin (2x3) GPS plug and I dont know which way to plug it back in .
The Controller is just a little white box , no lables apart from a disfigured small sticker with some numbers on it.
Any info would be appreciated ..
Thanks .
Hi sorry I can't help but have you done an image search of the internal items it may come up with a pic that will help you
Yes , done that however there is not much info on that particular version. If it turns out the FC is unrepairable I do have a KK215 control unit or a Naze 32 I could fit . I could do with finding out what esc units are on the craft.
Hi, yes I have and their wiring diagram for the gps is different. I will open the flight controller box to see what type of board is in it. And see if I can't find some info on it.
I think that's all you can do the wiring will be to match the board , fingers crossed you can find what board it is
If the esc units will work with a Naze 32 FC I might put in a new PCM radio and a Naze 32 FC which I happen to have spare.
