compatibility and reasonability?
jacktwaldron1
Someone who knows the specs and is experienced please help, I'm assembling my 2nd drone, A custom long range build on a frame I designed myself in cad and am currently printing. I think i finally found parts that are compatible and will work well for my build. After a ton of research and calculations this is what I came out with, Are there any major compatibility issues or problems using these parts this way?
Frame is about 350 grams, 26 inches rotor to rotor, plan on using 12x4.5 props.
Omnibus f4 V5 flight controller
Flysky FS6 system
Racerstar REV35 35A BLheli_S 3-6S 4 In 1 ESC
AIR 2216 KV880 motors
4s lipo, 80c, 3500mah, 400 grams aprox
Bn 220T gps module
Matek systems Power distribution board
AKK fx2 dominator VTX and JJA 1200tvl cam 250mw-2000mw
eachine rotg02 5.8g 150ch fpv receiver for tablet
Will all these parts work together?
i've calculated total build weight to be about 1400 grams including a gopro cam.
Will there be any issue using 12 inch props on these motors and will it provide enough lift?
