Close Call
GlassKnees
Wow, I somehow managed to avert disaster, though I don't know how. I decided to take out my modified Elev-8 out for a flight around the golf course, flying autonomously using waypoints I uploaded to the APM controller. I had previously uploaded a new version of firmware, then checked parameters and tweaked the compass declination a bit in order to get the aircraft heading to agree with my iPhone. Satisfied, I set up my ground station outside, fired up the quad and sent it on its way.
Almost immediately, I noticed something was wrong as it seemed to reach the first waypoint but continued on without loitering as I had expected it to. Then I heard a voice from Mission Planner say loss of GPS. I had already switched to RTL, but given that I had no (valid) GPS it was on its own, so I switched back to manual mode (Stabilize), but then Mission Planner said "No R/C". Crap. The aircraft is flying on its own and I have no control!
It seemed to respond to yaw commands, but I could not throttle down the aircraft even though I had my throttle stick completely in the down position. It was up pretty high and it was difficult to discern its orientation. Somehow, I seemed to regain control - throttle was responding and I managed to lower it and once I determined its orientation, I was able to bring it back close to my house, but I was not confident enough to attempt a landing on the pad I set up, so I managed to bring it down on the golf cart path behind my house - it settled down gently on the cart path and the motors shut down - whew!
I tried to play back the telemetry file but it doesn't seem to work, so all I have is the dataflash file to try to figure out what went wrong. Really scary flight, but at least it ended okay..
I decided to re-calibrate the compass and radio. Then I checked the value of the radio throttle failsafe setting - satisfied that it is below the minimum throttle value, I cleared the logs and took it out to a field for a test flight. The flight went well - in Loiter, it held position and RTL worked fine. I am guessing that doing the firmware upgrade messed with some of the calibration settings.
Loss of control is pretty scary, glad you were able to regain control and get your bird back. I know you've put a lot of hours into it!
Thanks! I brought out my laptop to the field for the second flight and when I reviewed the telemetry, I saw a voltage failsafe was triggered shortly after takeoff. I had almost fully charged the 4S lipo and so I was surprised at this. I checked the voltage record on the data flash log and saw then when I took off, the voltage dropped to around 14 V which is my failsafe trigger. I flew for about four minutes or so without any problem.
For some reason, I was not able to specify an action, such as Land or RTL when the voltage failsafe is triggered, so I just got a warning on Mission Planner. This morning, I calibrated the voltage sensor so that Mission Planner reads the same voltage as what I read with my multimeter, but I suspect that perhaps the lipo is failing to hold its charge and its dropping too much - may have to experiment.
I captured some FPV video of some of the original incident - video quality is terrible possibly due to a cheap camera but also, lousy reception from the aircraft to my monitor. I may post it - if I do, I will provide a link....
A new development. In trying to resolve the voltage failsafe matter mentioned in my last post, I attempted to run a test in my basement - flip the propellers so when I throttle the motors up, the props will push the aircraft downward; this way, I can run a power test safely in my basement. After arming the aircraft, I throttled up but the number 1 motor failed to spin. I tried several time, but no joy.
Not having a spare Tarot motor, I decided to swap the #1 with one of the others and run a motor test - again, the #1 motor (the motor attached to the #1 boom) failed to run. This means either a bad connection or an ESC problem. This is bad news because it means I pretty much have to disassemble the aircraft. So, over the next few days, I took it apart and removed the ESC's. Immediately, I noticed a problem.
Back when I first built this aircraft, I was concerned about voltage spikes from the side of the ESCs receiving main power, I decided to install 470 microfarad capacitors across the power and ground leads, but for some reason there wasn't one on the #1 ESC. My memory fails me but I suspect that I only had three capacitors and so didn't obtain and install a forth - DOH!!
So, I think I will replace all four ESCs. I don't think that I wll need the capacitors as they go inside the body of the aircraft and the power/ground leads are relatively short (shorter than they would be if installed out on the booms underneath the motors. I may document the rebuild process.
