GlassKnees
Wow, I somehow managed to avert disaster, though I don't know how. I decided to take out my modified Elev-8 out for a flight around the golf course, flying autonomously using waypoints I uploaded to the APM controller. I had previously uploaded a new version of firmware, then checked parameters and tweaked the compass declination a bit in order to get the aircraft heading to agree with my iPhone. Satisfied, I set up my ground station outside, fired up the quad and sent it on its way.
Almost immediately, I noticed something was wrong as it seemed to reach the first waypoint but continued on without loitering as I had expected it to. Then I heard a voice from Mission Planner say loss of GPS. I had already switched to RTL, but given that I had no (valid) GPS it was on its own, so I switched back to manual mode (Stabilize), but then Mission Planner said "No R/C". Crap. The aircraft is flying on its own and I have no control!
It seemed to respond to yaw commands, but I could not throttle down the aircraft even though I had my throttle stick completely in the down position. It was up pretty high and it was difficult to discern its orientation. Somehow, I seemed to regain control - throttle was responding and I managed to lower it and once I determined its orientation, I was able to bring it back close to my house, but I was not confident enough to attempt a landing on the pad I set up, so I managed to bring it down on the golf cart path behind my house - it settled down gently on the cart path and the motors shut down - whew!
I tried to play back the telemetry file but it doesn't seem to work, so all I have is the dataflash file to try to figure out what went wrong. Really scary flight, but at least it ended okay..
