Cheap FPV for a nano quad?
Tyler H
Hey I was just curious if anyone knows a setup that would fit on a blade nano qx 3d for fpv that the quad could actually lift? I would love to get into fpv but have no idea what camera/transmitter would be small enough for that size of a quad. thank you!
What type of budget? I have a couple ideas but they may be a tad over weight. If you are up for some DIY hackery you might get an ultra light setup for a few bucks.
@Mike H. would probably know about how much weight you can reasonable add.
Id like to stay under $100 if possible! I did some research and found these little spektrum mini fpv cameras that come with a transmitter and antenna for about $60-$70 but I don't know if that would be too heavy. What were you thinking?
Well, if you plan to record your flights and monitor them dont forget another $100 or more for a DVR monitor.
Hobby king has a tiny fpv set up much like the spectrum thats around 7g of weight and less money... but its a monitor thats going to throw you over your budget.
If you choose a larger quad its a much easier task to get into a budget fpv set up...In any case, expect to pay near $150.00 to do fpv with your nano QX
If you go with a larger quad such as a Syma X5C-1 you can get both the fpv set up and the quad itself for less than $100.00....Do yourself a favor and avoid the syma X5W wifi fpv model or the X5SC models for other reasons....the wifi fpv is garbage on any model or brand.
