Cant reverse roll gyro
jkmm
I cant reverse the roll gyro on my kk 5.5 Blackboard. I turned the pot all the way ccw, connected the battery, the light flashed 3 times, but then when ever I move any stick on the transmitter, the light turns on and when I release the stick, the light turns off. I am not varry expearienced at building quadcopters so please help.
hi mate this will help i sent it to your inbox too
6. Checking gyro directions:
- Take off the propellers.
- Turn on transmitter and flight controller.
- Set throttle to about 1/4. Motors should start.
- Tilt multicopter forward. Forward motor should speed up. If not, reverse pitch gyro.
- Tilt multicopter to the left. Left motor should speed up. If not, reverse roll gyro.
- Turn multicopter CW. Front and back motor should speed up. If not, reverse yaw gyro.
7. Reversing gyros:
- Set roll gain pot to zero.
- Turn on flight controller.
- LED flashes rapidly 10 times.
- Move the stick for the gyro you want to reverse.
- LED will blink continually.
- Turn off flight controller.
- If there is more gyros to be reversed, goto step 2, else set roll gain pot back
thanks. I figured out which gyro is reversed but when I try to un-reverse it, after I move the stick for the gyro I want to reverse, instead of blinking the led just turns on and it doesn't reverse the gyro. I think there might be a problem in the boards firmware.
