Cannot make the One Key Return function to work
tech5960
tech5960
Hi,
I read an article on the One Key Return feature and i would like to ask you all question about my Drone and and its RTH feature?
I have a Holy Stone F181C and when i press the RTH or One Key Return Button the Drone fly's away from me to about 150' or so and i have to call it back manually.I contacted Holy stone and they said that my drone will only fly to where it was "Bound" to instead of where the remote controller is located.The manual says to Bind.Calibrate the drone with the head facing away from me and i should stay still.I have done this numerous times to no avail and the drone keeps flying away from me to about 150'or so.Can you please explain to me what "Bound" means and also can you give me some advice on the best way to use this feature with my F181C.I really appreciate your time on helping me because i am at a loss as to what to do about making this feature work on my drone.Thank you so much for your time,tech5960
"Binding" is simply the process of powering your transmitter and drone, then quickly moving the throttle stick up then down which binds the drone to the transmitter. This is now your RTH spot and where your drone will return to when you activate RTH. So basically your RTH spot is where you bind your drone, not where you're standing. You should also recalibrate the gyro periodically.
