Best quad for the budget V2.0
loudbeat
Hi all again. I've searching and reading since the last time and I have taken note of your helpful comments for build my 250 quad.
This is the final outcome (I think).
x1 Radio Transmitter (Flysky FS-i6) $53.92
http://www.amazon.com/dp/B00VE3PZ3Y...TF8&colid=2DZ4SLJMXAQCB&coliid=I2EQEN0SI7QKWD
x1 Battery charger $15.97
http://www.ebay.com/itm/252065533285?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
x1 FRAME $37.99
http://www.amazon.com/dp/B00WE9EGAA...TF8&colid=2DZ4SLJMXAQCB&coliid=I2885JU7MWDCC6
x4 Motors (Emax MT2204) $53.99
http://www.amazon.com/dp/B00XY6SQQC...TF8&colid=2DZ4SLJMXAQCB&coliid=I33ITCT665XH44
x4 ESC (Makerfire 20A BLHeli) $35.99
http://www.amazon.com/dp/B01DEN46I6...TF8&colid=2DZ4SLJMXAQCB&coliid=I1IWENFSB9YPTH
x1 Flight Controller $22.55
http://www.ebay.com/itm/301831483381?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
x1 PDB With OSD $25.59
http://www.amazon.com/dp/B01CKWSGYC...TF8&colid=2DZ4SLJMXAQCB&coliid=I2UQH1ZB4W2EUY
x3 LiPo Battery (Tattu 1300mAh 75C) $71.97
http://www.amazon.com/dp/B013I9SYC0...TF8&colid=2DZ4SLJMXAQCB&coliid=I2HAU48T68PJ7T
x1 Quanum FPV Goggle $40.47
http://www.amazon.com/dp/B00YPZ9N4A...UTF8&colid=2DZ4SLJMXAQCB&coliid=IWZWBTQUI7905
x1 Booscam 32Ch Tx and Rx $32.87
http://www.amazon.com/dp/B00GWFUTSK...lid=2DZ4SLJMXAQCB&coliid=I1CCL5LH1PZUZB&psc=1
x1 FPV Camera PZ0420M $31.99
http://www.amazon.com/dp/B00PGFDSRQ...TF8&colid=2DZ4SLJMXAQCB&coliid=I2FKZLYW14454M
x2 8 set DAL props 5x4.5 $21.98
http://www.amazon.com/dp/B01CRCJMCK...TF8&colid=2DZ4SLJMXAQCB&coliid=I2YQ3KW9BE4F0G
What do you think?
Would you change something?
I know I pass a little of the $400 dollars gift card but is not much and the LiPo charger it is less than half the price on Ebay.
Would you recomend me a 3S 1300mAh 75C or a 4S 1300mAh 45C Tattu battery? (since they are roughly the same price).
I think I have to clarify something, I'm from Argentina so if something breaks it will be very very difficult to get replacements parts, so may be that's why i would like to have a robust build with less chance that something will burn.
Thanks again for your time and I'll be glad of hear any helpful comment.
Get the quantum V2 goggles, or the Quantum V2 Pro. If you get the Emax Redbottoms (EMAX RS2205 2300KV, which I strongly suggest) then I'd suggest some mini quad ESCs that do 30 amps burst. I'd also suggest that you get a more expensive clone of the Imax (around 21$ as they are higher quality and are less likely to have bad quality cause a fire) or go with the Turnigy Accucel-6 (Which will also do LiHV if you ever get something like the new Turnigy graphene batteries or other LiHV batteries).
Definitely get 4S, and the 70C Tattu racing series are great (I have one and another on the way).
Thanks a lot for the advices, but I only have a $400 dollars gift card on amazon to spend, I encourage you to read my first thread to know a little more of what Im trying to build
http://quadcopterforum.com/threads/best-quad-for-the-budget.8919/
Here's something to consider: Forget about all the FPV equipment and get better quality transmitter (Radiolink AT9 comes to mind), motors and ESCs. You'll probably have a little cash left for extra batteries and props. By the time you get really good at flying LOS, you'll have enough saved up for the other stuff. Just a thought
Probably you are right. but It is very hard and expensive try to import things in to my country, I wish I could buy all the things I want at any time, but here in Argentina we have some horrible laws and taxes, so I prefer to bring it all in once. All of this come because I was going to buy a LG G4 and encounter some troubles (the phone I received was fake) so I got a refund of $400 dollars on Amazon so I decide to spend that on a 250 quad with FPV. That's why my budget is a little limited. But anyway thanks for your advice. (sorry for my bad english)
Nothing wrong with the FS-i6 it's a great TX. And there is also a dedicated community of fans and ongoing alternate, custom FW development and RX tweaks. Need more than 6 channels? Just flash the latest custom FW.
Note how ch 5 has been set up to take advantage of the FCs with 6 flight modes.
Just saying. :)
No problem, your grammar is actually a lot better than most people here in North America hahahaha
Jajaja, Better that way. I like to be kinda efficient in terms of communication. Thanks!
Just saying. :)
Wow, Thanks for the info. It seems I have all the pieces almost ready to order. The only main doubt I have is in what's the difference between 3S 75C and 4S 45C batteries. Anyway it seems that either be a good choice. Thanks!
