Beast SG906 PRO advice
I myself have tried calibrating multiple times with unpredictable results, only had it about a month flown it 7x , 2 successful flights , 1 in desert could not handle the wind I was ok with it , the dj air2 power thru the wind. another time keep getting magnetic error an could not fly , I was on an open farm field! next day it hover steady on a park hmmm but could fly as it was prohibited .
Today it drifted into a wall , swapped props same results went up briefly hovered an than drifted again into a tree , I have 12 satellites so should hover , im very frustrated an advice will be highly appreciated.
This does not seem to be related to compass calibration (what you are doing). It seems to be that either your propellers are bent/broken or damaged (from accidental hits prior), or your gyroscope is not calibrated on a completely flat surface (is this box in the middle of the garden as level as "water surface"? It needs to be really *level* not just "flat". Thirdly, check the lower camera (for "optical flow") not to be damaged, scratched or dirty. If the "flow control" does not work - your copter is not going to be able to "hoover" in one position.... If all of the above is ok, try to see if your controller sticks are in "neutral position" before you "take off" (let is rotate 5-10 seconds) before "lift off".... Hope your controller is also not sending wrong signals... Hope it helps... It is a good drone(!), mine does not do such weird things at lift off. Sometimes after a few minutes of flight it can "rush a bit away" but this may be also related to bad batter dropping the voltage too quickly...
