BAYANGTOYS X16 2.0MP WITH BRUSHLESS MOTORS
seems like you could use standard props and any battery that fits in the compartment at 11.2 volts. Would like to know if anyone has purchased one. Very x8c like but with brushless motors and a barometer for altitude hold.
So what props didya get for spares? With no prop guards you will be SOL with the first prop that breaks, which may come very quickly. What didya do for another battery?
I haven't gotten the unit yet, but I am planning to get spare props here, there are a couple of hobby shops near my place that sells spare parts for drones, I think there will be no problem fitting aftermarket props, I just hope the prop of the X16 has standard diameter holes, if not I'll just have to re-bore the holes to make it bigger, not really new to customizing RC stuff, I tinker a lot! LOL, I'd probably get carbon fiber props and those ABS plastic props, and balance it myself. For a battery spare, I haven't decided on a battery yet, I think 2500mah battery or 2700mah spare, and if higher rated batteries will fit, then I'll go for the higher ones... btw, also planning to get a Xiaomi Yi action cam and install it on the X16. :)
Are you looking for a connector to plug an XT60 connector battery into a balance charger? If so, then yes.
I was looking for the "generic" battery for X16 but only found those batteries had XT60 connector.
Now after I had searched there are batteries have 11.1v 2200mah have those "banana" connector at taobao, I think all batteries come from China.
https://world.taobao.com/item/53936...1.14.28.ebb2eb2utrc2m&ns=1&abbucket=11#detail
https://world.taobao.com/item/52051...1.14.16.ebb2eb2utrc2m&ns=1&abbucket=11#detail
Actually what is the "proper" name call those banana plug type?
3.5mm?
Also, should I take the 25c or 35c?
What type of the charging connector? XH-4P?
