I have a little fast lane hornet striker drone. The batteries are gone,(wear& tear). Takes 3.7v200mah battery, would putting a 3.7v250mah battery cause any damage? For example..overheating the motor, or anything like that?thank
Hi mate No thats ok you can up the MAH you cant up the voltage , the mah will give you longer flight times just be careful as the mah comes up the thickness of the battery can change
