Battery Connector Types?
HiDesertHal
What type of connector is used on the 1300MAH Li-Po TX battery of my Hubsan H501S? (See pic.)
I want to order a 2000-2500 MAH Li-Po to velcro to the back of the TX for longer times between charges.
I'm not sure if it's a Deans connector, so what type do I need to connect to the TX?
Thanks,
HiDesertHal
I believe it's a "JST" connector and more than likely an RCY
(check the distance between the pin's tips is 2.5 mm). :)
The suffixes go like this:
GH=1.25 mm, PA=2.0 mm, RCY (or SM) =2.5 mm, VH=3.96 mm ;)
