Pretty much. Try a 31mm or 62mm length.WILL ANY PIECE OF WIRE WORK
Well you will want the antenna to be of a length that supports resonance with that frequency. Basically that is a fancy way to say that the length determines what frequency is picked up best by that antenna. Also most antennas will use coax where the conductor is suspended directly in the center of the ground. I'd suggest you buy a cheap $0.75 wire antenna for 2.4 GHz antenna and solder it on.LOST ANTENA OFF DRONE WILL ANY PIECE OF WIRE WORK IT IS A SYMA X 5 S W
I have a old FlySky 2.4 GHz 8ch receiver which has a wire and something on the end. If I unsolder it from the receiver then solder it on the X8C receiver board. Would that work and help on the range? I have FlySky FS-CT6 transmitter could do the same to the X8C transmitter to?
If I go with this route and use a wire and cut it 62.46mm how much more range will I get? If I change the wire in the receiver board to would the wire be cut to 62.46mm to? I have a Digital Caliper to cut the wire exact length on both.... Also of note, if you use "any piece of wire" (which WILL work just fine as long as it's the proper length) is that the "active" part of that wire
(IF you're using coaxial wire that is) will be only the length which is stripped and not covered with the shield. And remember the shield has to be
soldered to ground! (this comes in handy when wanting/needing to remote locate the antenna like with racers or as an improvement mod to your
Syma) otherwise the antenna will consist of the entire length of wire .... Better reception will be had by using a half-wave antenna (62mm)
instead of the quarter-wave (31mm) length too, (actually 31.23mm or 62.46mm to be exact)
When making the new antenna you want to use a longer than needed piece and first solder it onto the board,
THEN cut it to the correct length as measured from where it contacts the solder of the board to the end of the wire![]()
Don't touch it, leave it be as you may ruin your PCB. Learn to fly the thing first, you can worry about antennas later if you find the range lacking.If I go with this route and use a wire and cut it 62.46mm how much more range will I get? If I change the wire in the receiver board to would the wire be cut to 62.46mm to? I have a Digital Caliper to cut the wire exact length on both.
I was just asking beside that what I was going to do. I'm trying to learn as much as I can.Don't touch it, leave it be as you may ruin your PCB. Learn to fly the thing first, you can worry about antennas later if you find the range lacking.
Sounds like good idea.Syma X13 to learn how to fly inside
As Jackson said, I have to learn how to fly first.Learn to fly the thing first
