AEE Toruk AP11. Compass Calibration Failed
AlexToruk
Dear Sirs,
Please help me to fix the issue with quadcopter, described below.
Model: Drone AEE Toruk AP11
Problem name: AEE Toruk AP11. Compass Calibration Failed
Problem description: Device indicates compass calibration failed and don’t pass compass calibration process
How to replicate problem:
  • Power on remote control unit
  • Power on main unit
  • Wait about 20 secs
  • Make sure, that connection between main unit and remote control is established and regarded status is indicated on the remote control
  • Obtain that main unit has following light indication:
  • Front indicator (green) is fast blinking ( 3 times per sec)
  • Rear indicator (red) remains ON
  • Obtain, that such indication means “Compass calibration Failed”. That it Not Good.
  • Try to make compass calibration by following steps
  • Switch S4 for more than 5 times between GPS and Follow Me mode. The quadcopter will enter calibration standby mode(the tail light blinks fast).
  • Toggle the joysticks to the position: left-top and right-top.
  • Expect front indicator (green) to start blinking to indicate that compass calibration command sent successfully
  • Obtain, that front indicator (green) is not changed and compass calibration command is no accepted. That is Not Good.
What wrong is obtained:
  • device indicates compass malfunction on step 6
  • device doesn’t accept compass calibration command on step 11
What is demanded:
  • device to accept compass calibration comment and pass successfully compass calibration process
Questions:
  • What could be root cause of compass calibration failed indication?
  • Could root cause to be damaged compass?
  • How to force device to accept compass calibration command?
  • How to open main unit?
  • How to found compass?
  • How to replace the compass?
  • Where to buy new compass?
Please send your answers to: alexander.jermakov@gmail.com
Thank you,
Alexander Jermakov
