Dear Sirs,
Please help me to fix the issue with quadcopter, described below.
Model: Drone AEE Toruk AP11
Problem name: AEE Toruk AP11. Compass Calibration Failed
Problem description: Device indicates compass calibration failed and don’t pass compass calibration process
How to replicate problem:
Questions:
Please send your answers to: alexander.jermakov@gmail.com
Thank you,
Alexander Jermakov
- Power on remote control unit
- Power on main unit
- Wait about 20 secs
- Make sure, that connection between main unit and remote control is established and regarded status is indicated on the remote control
- Obtain that main unit has following light indication:
- Front indicator (green) is fast blinking ( 3 times per sec)
- Rear indicator (red) remains ON
- Obtain, that such indication means “Compass calibration Failed”. That it Not Good.
- Try to make compass calibration by following steps
- Switch S4 for more than 5 times between GPS and Follow Me mode. The quadcopter will enter calibration standby mode(the tail light blinks fast).
- Toggle the joysticks to the position: left-top and right-top.
- Expect front indicator (green) to start blinking to indicate that compass calibration command sent successfully
- Obtain, that front indicator (green) is not changed and compass calibration command is no accepted. That is Not Good.
- device indicates compass malfunction on step 6
- device doesn’t accept compass calibration command on step 11
- device to accept compass calibration comment and pass successfully compass calibration process
Questions:
- What could be root cause of compass calibration failed indication?
- Could root cause to be damaged compass?
- How to force device to accept compass calibration command?
- How to open main unit?
- How to found compass?
- How to replace the compass?
- Where to buy new compass?
Thank you,
Alexander Jermakov
