Accidentally plugged in battery backwards...
Chris
So I recently ordered and obtained this Aerosky H100 quadcopter from Xheli
http://www.xheli.com/05h100-quadcopter-green-rtf-24g.html
The quad was working nicely, until I screwed it up. I had some batteries with deans connectors that I wanted to switch out for the banana plug adapter on my quad. However, I accidentally ordered the esc connectors...
This is what I ordered: http://www.hobbypartz.com/98p-4mmbanana-for-esc.html
This is what I should have ordered: http://www.hobbypartz.com/98p-4mmbanana-for-battery.html
When I soldered up the new connectors, I failed to notice what was wrong. Upon plugging the new battery into the quad, there was a spark, and a puff of smoke. I looked down to realize that I had connected the negative end of the battery to the positive end of the quad, and the positive end of the battery to the negative end of the quad. Now the quad will not power on. Which component should I look to replace if I am to save this quad?
More than likely, your ESCs took most/all of the damage. And of course, you probably don't want to use that battery again.
