The ZTWs did not have  three wires- just the  signal and -black. I have some of those little red two pin plug and socket which I soldered onto the ubec and  that into motor 1 esc.
Sorted out the  motor  wires to get the correct  rotation and setup the KK2.1.5. Its on "factory settings"  and the  now wonderfully working Devo 10 did its job and so with the help and advice given  here and other threads..the 450 frame is done - to the point it  needs tuning to sort out the flying side.
Its quirky  just now I can  get it up on hover... but its drifts badly - although not wobbly. If I try to counter the drift... it  does a double speed flip into the deck!
So tomorrow will be taken up on you youTube - tuning the KK2.1.5 and Devo 10 stuff.
Final Build list:
450 DJI copy Frame ( eBay)
ditto landing legs ( I got two sets 1 white - one black and mix them)
Mars motors 2212 980kv
KK2.1.5 Flight Controller
ZTW Spider Opto oneshot 125 ESC
HobbyWing  uBec
4500mAh  3s LiPo
Genuine DJI Phantom Props - started out white - I added  colour tinting!  ( available in Yellow, Orange, Dark mucky Red, Denim Blue( add yellow) Grass green.
Also
A truck load of cable ties,  heat shrink tube in all sizes and colours, screwdrivers, battery straps ( all too big!)  30  m/f T60, 30 m/f Deans, 30 3mm bullet plugs m/f  - same in 2mm - I ordered wrong off eBay...plus  a lot of other bit s I thought I might need... and did not - such as a  servo consistency gizmo and  voltage indicator.
All I need do now.... is sort  out the setting and let it fly!
I dont have any online  accounts for uploading pix...sorry..
Thanks to all you guys who  gave your time and patience to help  through all this........ don't  go away.... I still need you - I have another load of parts and 500 Alien  frame to build!  Then its  250 racer.
  (mmm on reflection and chaos with teh KK2 - maybe not!)
