FirstPersonView
Blog post!
NEW UPGRADED ZENMUSE H3-3D BRUSHLESS GIMBAL!
THE ALREADY AMAZING DJI ZENMUSE HAS NOW IMPROVED EVEN MORE. DJI HAVE ADDED A THIRD DIMENSION CREATING A HIGH QUALITY, PRECISE, 3-AXIS BRUSHLESS GIMBAL.
Buy now from FirstPersonView.co.uk
The Zenmuse H3-3D gimbal is:
· Strong
· Lightweight
· Compatible with almost all DJI flight control system
· Brushless gimbal: brushless gimbals are more beneficial than gimbals that use servos as there are no gears, no notchiness and therefore they produce a much smoother picture.
The H3-3D is designed to work with the GoPro 3 and 3+ (Black and Silver). It is highly precise to a degree of ±0.08° meaning you can achieve fantastic, smooth footage that can be used for anything from film and TV to cinematography. That shot you’ve always wanted to be able to get will be easily achievable.
The gimbal is plug and play, so it’s easy to install.
The independent IMU is easy to install and provides precise attitude data and improved control accuracy Get yours now!
SPECIFICATIONS:
· 3-Axis gimbal
· Aluminium alloy body – makes the gimbal lightweight; only 168g
· Brushless motors
· Built-in IMU module
· State of the art Zenmuse algorithms mean the H3-3D provides pixel level stabilisation
· Input power: 3s-6S Lipo (12V-26V)
· Dimensions: 97mm x 95mm x 73mm
· Controlled angle accuracy: tilt/roll: ±0.02°, yaw:±0.03°
· Tilt axis control: -130 ~ +45°
See FirstPersonView.co.uk for more information
Yes I will also post in the firstpersonview bit....
· Strong
· Lightweight
SPECIFICATIONS:
· 3-Axis gimbal
· Brushless motors
